Experienced Mechanics
I was wondering if anyone here locally would install my Clutchmasters Stage 3 Clutch and My either Toda or COmptech Flywheel? I will pay and I will also provide beer or liquor of some sort if neccessary...Also, I would like to learn not in depth but just see the step by step procedure...If anyone is up for the challange and HAS DONE THIS ALREADY ON AN S2000 then PM or post and we cna work it out from there...And no high numbers or else I can get my tuner to do it but trying to save money...
Yea that is kinna high at least for me...Because the shop I take it to said they will do it for $350 OTD...I was wondering if anyone here knew how to do it and needed some extra cash helping the person installing out and helping myself out! Thanks for the quick responses!
it's a bigger pain to "teach" someone the process than to just execute the process itself. tis' the reason our k-12 teachers are generally considered underpaid.you do realize breaking the flywheel nut off (often) requires an impact gun capable of 400lb-ft+ of tq? and can be quite a bitch? o wait, no you don't, because you "would like to learn". not to mention a clutch job requires dropping the transmission, the drive shaft, yankin out the shifter, replacing pilot bearing (hence a bearing puller), ad nauseam... and THEN you gotta slide that beast of a transmission back ONTO the drive shaft which can take an hour if you're not lucky..
the proverbial: "you gotta pay to play" cliche applies here.
Originally Posted by ToeKneeC,Feb 20 2006, 05:10 PM
waitamin... if pinyo's shop (a relatively reputable shop no less) said 350-400, and your shop said 350.. how's pinyo's shop "kinna [sic] high"?
I'd take it to Pinyo.
I'd also recommend Pinyo, he knows this car backwards and forwards. I've watched him put in my clutch and it was no easy job. But its your money and if you think your tuner can do it cheaper and not royally screw it up then go with them.
EDIT: I just noticed that your sig indicates that you have the UR turbo kit installed on your car. More than likely the turbo, manifold, downpipe, and IC piping will have to removed/re-installed for the clutch installation. The extra time for this will need to be factored into your estimate.
I've never replaced a flywheel on a S2K motor but I've taken apart a few honda motors and I don't ever remember seeing a flywheel nut holding the flywheel to the crank. Maybe it's something new
I do remember seeing flywheel bolts though. I also remember that it took an impact to get the crank pulley bolt off but that has nothing to do with replacing a clutch or flywheel. Sorry, just a little confused about this flywheel nut.
Im sure Pinyo/P&L wont mind you hanging around while they do the work - but thats for them to comment on - but if you dont want to spend that kind of money then IMHO I would just get it fixed at your local shop.
Honestly I dont think you are going to get the "ill throw you a couple of cases of beer in return for a clutch install" kinda deal from anyone here - especially given the outside temperatures right now.
