Part number help needed...
Need part numbers, please.
If anyone has access to a manaul, can someone find the either the size and/or the part number of the 3 bolts that are used on the flange from the catalytic converter to the flange on the main exhaust pipe?
I forgot to check the manual on my way out to work this morning. I need to pick up these bolts on my way home from either the Acura or Honda dealerships on my way home.
Thank you.
Thank you.
From the picture, the arrow is on the 10 x 1.25mm self-locking nut. Unfortunately, it's not a 10mm....it's a 14mm. I'm looking for the part number for the bolt that goes to that nut...
The 8x1.25 spring loaded bolt attaches the cat to the exhaust manifold (header). Thanks though.
Actually, I got the part number from a post in the 'UTH" section.
