Upper Mid-West S2000 Owners Members from the upper mid-west including Michigan, Illinios, Indiana, and Wisconsin
suggestion for lowering spring
Old Feb 16, 2006 | 11:18 AM
lend_type_R's Avatar
Default suggestion for lowering spring
what brand can you recommend for just a spring. im planning on an inch low but i dont want them to sag as time passes by. i need you help guys. im looking at the tein s tech,eibach and skunk. are these good springs base on your experience? and where can i have them installed with a good price?
Old Feb 16, 2006 | 11:54 AM
ruexp67's Avatar
Well, any spring will wear the stock shock out faster. This will really be the problem long before "sagging" springs.
It is hard to make comparisons as most people just buy one set and rock those. I have espliers as do quite a few others here. Although they will drop the car more than 1" (more like 1.75")
P&L Motorsports would be a good place to get them installed. One of the guys there, Pinyo has an S2000 and is active on S2ki under the screen name profpin
Send him a PM for a quote on springs and install.
Old Feb 17, 2006 | 12:32 AM
thanks.really appriciate your help.
Old Feb 17, 2006 | 02:40 PM
profpin's Avatar
pm sent..
Old Feb 18, 2006 | 08:26 PM
SilverBullit02's Avatar
Look no further than right here.
http://www.ground-control-store.com/produc...hp/II=526/CA=76
I have them. They are fabulous. Quality is outstanding to say the least. Completely adjustable ride height.
Old Feb 19, 2006 | 04:55 AM
DISCO_J's Avatar
took mine there and Pinyo did the install. Very relax atmosphere, more like hanging out and getting work on your car at the same time. He does an excellent job too.
Old Feb 20, 2006 | 12:13 AM
thanks!like the looks of it. but my main concern is that ones i lower the car with these adj spring the ride would be more bumpy compared to lowering springs. coz most of the adjustable springs are bumpier as you go lower. but if these springs are set to an inch lower got same ride as those of an ich of lowering springs, then i might consider of installing this brand.
Old Feb 20, 2006 | 04:34 AM
S2000GT's Avatar
Ill give another vote for Espelirs. They will lower you more than 1" but they have a great ride.
Pinyo also did my install (remember that one Pin? )
Old Feb 20, 2006 | 01:16 PM
S2kracka's Avatar
Swift.
Old Feb 20, 2006 | 07:44 PM
They are not actually bumpier as you go lower because of the spring. If this happens, the problem is that the shock is not properly valved for the spring rate or the car is so low that it is riding on the bumpstops. Personally, I would never lower a car without getting a properly valved set of shocks at the same time. I recommend Konis. You will get better performance from a set of Konis and Ground Controls than you will from most of the JDM coilovers.
