10mm spacers..
for s2000, is it safe to run 10mm spacers on rear w/o longer stud?
I was just reading spacer group buy thread, and someone said longer stud is only required when running 15mm or more. anyone running 10mm spacer? |
yes you do need a longer stud forsure. I'm running a 5mm and needed longer studs.. it's not safe without them.
thanks!!
more money needed... :( |
And to properly change the studs, you will need to remove the knuckle and there is a chance you will need to replace the wheel bearings.
Omfg I hate doing lugs. If you do spacers just go with those spacers that have extended lugs integrated. I switched my lugs before and it was $$$$. Pita too cuz you have to press in the bearing which is more $$$. Had to pay someone to do it.
well.. the thing is, with 10mm spacer, you will need to cut off part of stock stud..
anyways, what's the thickest spacer that I can put on before I need longer stud? 5mm plate? 7mm plate? |
Depends on the wheels you want to mount.
To safely bolt on the wheels, you want at a bare MINIMUM 6 threads. Don't cheap out for the sake of saving money because the cost to fix it when it goes wrong will be much greater than the $$$ you saved. I've run 3 mm spacer with the stock ap1 wheels and it was pretty close. Maybe 5 mm would be max, safely. |
^ I run 5mm. Not safe. Need longer studs at 5mm.
