clutch pedal stuck
Hi..
need some help here.. i bleed my clutch... and now there's no pressure on the pedal at all. it just goes straight to the floor. it was working fine b4.. any idea? |
Sounds like it wasn't bled correctly.
Try pumping it like a lot of times after you top it off. It seemed to work for me although I need to check up on it.
Yup sounds like air still in the system.
i've gotten someone to lift and pump the pedal while i control the bleed valve... and we've been at it for 30 mins... and all i get is air out. i'm giving up soon. u guys know any mechanics tat do house calls?
have you ever bleeded the clutch by yourself? it takes a lot of tries, and you can't let air back into the system or else you have to start over...
you kinda need another person to keep adding fluid if you're bleeding it too fast... where are you located, i could make a housecall (but i'm not a mechanic), but i have replaced my clutch master cylinder at home, so i think i can figure this one out |
This truely is a great group of people...,
okay i've got it fixed... thanks for all your inputs..not sure what the prob was the 1st time but i reverse bled it and i got pressure back. but somehow my engaging point has changed and i have to release the pedal 3/4 on the way up b4 it engages.... it was in the middle b4 i bled it.
