clutch pedal stuck
clutch pedal stuck
Hi..
need some help here..
i bleed my clutch... and now there's no pressure on the pedal at all. it just goes straight to the floor. it was working fine b4.. any idea?
i've gotten someone to lift and pump the pedal while i control the bleed valve... and we've been at it for 30 mins... and all i get is air out. i'm giving up soon. u guys know any mechanics tat do house calls?
have you ever bleeded the clutch by yourself? it takes a lot of tries, and you can't let air back into the system or else you have to start over...
you kinda need another person to keep adding fluid if you're bleeding it too fast...
where are you located, i could make a housecall (but i'm not a mechanic), but i have replaced my clutch master cylinder at home, so i think i can figure this one out
okay i've got it fixed... thanks for all your inputs..not sure what the prob was the 1st time but i reverse bled it and i got pressure back. but somehow my engaging point has changed and i have to release the pedal 3/4 on the way up b4 it engages.... it was in the middle b4 i bled it.
