excessive wind noise?
im not sure about other 01 S2000's, but ive been noticing a lot of wind noise coming in from where the soft top meets with the top of the wind shield.
I cant feel where exactly the air is coming in from, so not sure of what the problem might be.
I hear the air starting to pass in more when im going 120+.
When i go and lock down my top, the 2 latches seems to pull the top down quite hard. and the top doesnt "fling" move around at all once its secured.
What would you say the problem is? is there something that needs to be changed?
Or are my ears just over sensitive, which may be the case from time to time
Thanks!
Just did a quick read on this and it sounds easy enough.
Will do it once i get back to Van.
Heres a great info page for anyone else whose interested in doing this
https://www.s2ki.com/forums/index.ph...ic=578316&st=0
