Rattling?
if your soft top is rattling...its most likely your soft top strikers the metal piece that the hooks hook onto.
you can order new ones..they are about 60 dollars each. im ordering some soon to replace mine.hopefully it'll help with the wind noise at highways speeds
I've had the top rattle occasionally -thats good to know about replacing the strikers, thanks Kenny.
I've hit a pothole and caused a rattle in the right rear -that is until i retightened the spare tire retainer
u can pick them up at a local honda dealership
or you can order them online through www.hardtopguy.com
ill prob just pick them up at my dealership at my cost.
They are the pieces that your hooks (that you use when closing the top) hook in to. If your car is mid 02 and beyond, they should have the new strikers. The "new" strikers are the ones that come with the hardtop.
I would also take the advice about the spare tire nut. I had a rattle that drove me nuts and then finally checked the spare, and sure enough it was loose.
I also find that occassionaly the passenger seat belt buckle rattles if it is in a wierd position.
