Vancouver BC S2000 Owners Meet fellow owners in the Canadian province of British Columbia.
Rough shift from 1st to 2nd
Old Oct 3, 2006 | 06:28 PM
preeeeluuude's Avatar
Default Rough shift from 1st to 2nd
Any other locals have this problem? Almost everytime i shift from 1st to 2nd gear the shift is not smooth like it would be when shifting into any of the other gears. The shift feels stiff and is accompanied by a sort of clunking or clicking sound that is uncharacteristic of any of the other gears. This seems to be a commom issue from what I have read over in the tech forums, however, many mention that the notchiness goes away as the car warms up. Mine on the other hand seems to be constant.
Anyone who has this problem or have had this problem ever get it checked it before?
Old Oct 3, 2006 | 07:50 PM
TOUGH DUDE's Avatar
i have the same problem on mine as well, it's really a pain in the ass
when you race someone. warming up the car doesn't help at all.
not sure if this's common or not.
Old Oct 3, 2006 | 08:37 PM
asdfg123hk's Avatar
yea it sux...that's why i hardly vtec in 1st..then again..i think it's common on all s2ks...
i find 1st to 2nd smoother after some hard driving..basically the harder i drive, the smoother it gets..anybody with similar experience?
but then...wut annoys me most is that the car sometimes pop out of 1st gear (only happens from a standstill)..
Old Oct 3, 2006 | 08:55 PM
WtbS2k's Avatar
Yea, i have the same problem. sometimes it just grind.
Old Oct 4, 2006 | 09:34 AM
kenny_son's Avatar
wow...2 new members i havent seen before!!!! where are they coming from!?!?..come out to the meets guys!!! haha anyways
ya i get the 1st to 2nd clunky shift. once my car warms up it goes away though.
Old Oct 4, 2006 | 11:39 AM
WhiteS20000's Avatar
same here 1st to 2nd & 2nd to 3rd are hard to engage but after car warms up it goes away. between i'm a new member as well. will post pic later on just having too many midterms right now. ~ peace~
Old Oct 4, 2006 | 12:05 PM
qorn's Avatar
Sometimes I find that it requires extra effort to shift out of 1st or 2nd into neutral. I depress the clutch all the way to the floor but the shifter doesn't want to release out of gear. With a little extra force the transmission goes to neutral, but this requires far more effort than should be necessary.
e.g.) I'm driving along in 2nd gear at 40km/h. I'll press and hold the clutch all the way to the floor, but the car will stay in gear (the shifter is still in the gate for 2nd). When I experience this problem if I let the car slow down in 1st or 2nd to a slow speed of 10-15km/h then the gear releases on its own. You can feel the difference in the transmission when it releases. Has anyone else experienced this problem?
It feels as if the car stays in gear even though the clutch is pressed down to the floor. Any idea what this could be? It doesn't happen all the time, and seems to happen when the engine is both hot and cold. Any ideas what it could be? The car has 67,000kms. Please don't tell me that I need a new clutch. Normally everything is fine, it only happens once in a while.
Old Oct 4, 2006 | 12:28 PM
sYnth.'s Avatar
I used to have the odd 1 -> 2 gear shift gring. I changed my tranny fluid to Redline MTL and the problem went away. The Honda MTF was poison to my tranny and I know other people on the boards have had problems with it. So if you're getting grinds change your tranny fluid to Redline MTL and it may fit your problems. Since changing the fluid I can shift from 1->2 as fast as I can and have not experienced any grinding. Try it out.
Old Oct 4, 2006 | 01:01 PM
kenny_son's Avatar
nice , i think im going to try that...but first i have to find out how or who can do it?!
Old Oct 4, 2006 | 04:25 PM
thanks for that tip.
where can i get this redline mtl though?
