Vancouver BC S2000 Owners Meet fellow owners in the Canadian province of British Columbia.
Spark Plugs
Old Apr 27, 2009 | 04:46 PM
SVtec's Avatar
Default Spark Plugs
hey guys/gals im thinking to change my spark plugs and was wondering where do you get yours from ?
they all perform the same right..? i was thinking to get from honda but backed off for now because the guy quoted me around 120$ for 4.... kinda pricey
any tips? thanks in advance
Old Apr 27, 2009 | 05:15 PM
chad86's Avatar
just go to a local lordco they can get in some good ones for cheaper probably...I usually say i work at a dealership so i can score a little discount as well... they are usually really chill about it... if u are changin them out yourself i would torque them a couple more lbs than honda recomends.. they seem to come loose on our ap1's... i think they recomend 15 or 16.. i did mine at 18 lbs....
Old Apr 27, 2009 | 07:16 PM
SumAznGuy's Avatar
I just bought some platinum NGK plugs from Crappy Tire for $10 a pair.
CT didn't have ones listed for the S, but cross referencing them, they share the same part number as the CRX's on the Boshe plugs so i went with the CRX ones in the NGK G-powers.
When changing the plugs, becareful putting the plugs in. You do not want to cross thread the plug into the head. Also, most torque wrenches are not that accurate when it is such a low number as 15-18 ft/lbs. I usually go hand tight, then add 1/4 turn with the wrench.
Also, get a plug gapping tool to double check that the plugs are gapped properly.
Old Apr 27, 2009 | 07:45 PM
Lunacy's Avatar
Should be around $18 for a plug from Honda.
they should be NGK platinum PFR7G-11S
Old Apr 27, 2009 | 09:32 PM
SVtec's Avatar
really? hmm strange which honda location is this from?
Old Apr 27, 2009 | 09:49 PM
alSpeed2k's Avatar
I second Edwen, CT actually has pretty good prices on NGK plugs!
Old Apr 27, 2009 | 10:29 PM
chad86's Avatar
Really?? hand tight and 1/4 turn.. You have never had any problems with them coming loose?? Maybe it was only in the early ap1's.. I am just paranoid when it comes to that because I have had a plug blow out on me before...and that was no fun...
Old Apr 27, 2009 | 10:40 PM
rk604's Avatar
i got my sparkplugs for 15$ a piece from AJ Racing ...
after the change, i noticed my gas mileage increased close to 50KM...as my old plugs were really bad
Old Apr 28, 2009 | 02:50 PM
SumAznGuy's Avatar
I have a steel bridge I can sell you, or beach front property in Oklahoma.
Poor gas mileage due to old plugs is quite common. To spend $15 on a plug is a bit extreme. Honda is over charging for those NGK's. With the part number, those plugs can be bought from Lordco for $11 each, and that is already on the high side.
As for the plugs blowing out, there is no reason for that to happen as long as they are properly tightened. The difference between 15-18 ft/lbs is not noticable at that low amount. Most torque wrenches are not that accurate at that low amount. But it is worse to cross thread or strip the threads by over tightening the spark plug.
Old Apr 28, 2009 | 03:08 PM
DDonovan's Avatar
Don't skimp, go for the good stuff...,
