Vancouver BC S2000 Owners Meet fellow owners in the Canadian province of British Columbia.
Swift tech spring question.
Old Apr 8, 2010 | 05:42 PM
  #21
praisedprod's Avatar
bump stop is exactly what it does. Its only purpose is to stop the piston from bumping the the bottom of the strut
Old Apr 8, 2010 | 11:21 PM
  #22
truong's Avatar
Really? This is intresting because cutting the bumpstop on a tsx I recently did dropped it 1 finger gap.
I installed them and about a week after the owner really didn't like the front sitting higher then the rear.
Cutting the front bumpstops lowered the front
So I'm a bit confused. I don't really want to argue and defend my point because i honestly don't know. But it worked for a lot of the cars i've seen
Old Apr 9, 2010 | 01:40 AM
  #23
turbo_slug's Avatar
on some cars (eg. miata), the car sits on the bump stops. by sitting on the bumpstops, the suspension starts off as soft then gets progressively stiffer as the bumpstop compresses...
Old Apr 10, 2010 | 03:53 PM
  #24
Red 5's Avatar
Truong, are you a mechanic at Gearheads?
Old Apr 10, 2010 | 08:30 PM
  #25
ohkun's Avatar
ok... I had a chance to check the springs today.
turns out.. springs ARE installed correctly.
now I'm even more confused...
I'll try pre-loading suspension.
for the front, do I loosen bolts for just upper A arm? or bottom one too?
Old Apr 10, 2010 | 10:36 PM
  #26
truong's Avatar
No I am not, But allan from gearheads is my mechanic. Why wussup?
Old Apr 11, 2010 | 02:28 AM
  #27
tsukubaSpec's Avatar
i got my old espelir asd springs installed by AjR and they didnt preload the front so my rear was lowered and the front was like stock, i end up loosing up all the bolts,dropped the weight of the car on the front suspension and i gain almost 1 inch and half !!
im pretty sure your having the same problem !!
Old Apr 11, 2010 | 03:25 PM
  #28
Yeah, same here. They told me they never do, no need, guy at the alignment place thought that was crazy. For the price they charge you can't go wrong. I paid the alignment place a few bucks to go around and re-torque everything and it is allot easier cause the car all four wheels on the the rack. I can give you their info if you like, they seem like some good guys. Dropped them off a case of beer after
jp182
Jul 10, 2018 02:38 AM
acelaluces
Mar 23, 2011 06:51 AM
plow15
Apr 14, 2007 08:22 AM
s2kpdx01
Aug 7, 2002 05:16 PM
