Winterize
Wash n wax...helps repel the salt...
Snow tires is a must if u plan to drive thru heavy snow conditions
If storing then fill up, change fluids that need to and if possible put car on jacks.
Originally Posted by Team1!!111!!!,Dec 13 2008, 12:09 AM
If I were to store my car for winter, do I need to put fuel stabilizer in if I'm going to start the car up once a week? Thanks.
https://www.s2ki.com/forums/index.php?showtopic=247621
Use fuel stabilizer if you are going to park your car for any amount of time. The gas in the tank will turn to varnish if you don't. And when you run the car, the varnish will gum up the injectors and fuel lines. Cheap insurance.
As for winter, check the coolant. Try to keep 3/4 tank of gas in the car. Last thing you want to do is run out of gas.
SNOW TIRES. Make sure the tires are properly inflated.
Lots of washer fluid. New wiper blades.
Keep some salt or sand in the trunk in case you get stuck. Some candles and water in the car incase you get stranded. Extra clothing and blankets.
The oil in the motor will flow down to the oil pan leaving the internals to have metal on metal contact for the first few seconds upon motor startup. It takes a little bit of time before the oil pump pumps the oil to the top of the motor.
Also, normal engine operation will produce water in the exhast. Without high temps, the water may pool in the exhast and now your exhaust internals might rust out.
