I have a *brand new* F1 Racing Stage 2 Clutch Kit as well as an F1 Racing Lightweight Flywheel, purchased through BrakeOptions here on S2KI. I was going to use it for my NA build, but I decided to go Turbo after much thought. I paid $537.00 for everything, but I will let it go for $475.00 shipped. Here are some pictures of everything:
Flywheel
* Ultra heavy-duty and weighs only 10.75 lbs (stock flywheel weighs 16 lbs)
* Meets or exceeds SFI 1.1 specification
* Made from 4140 forged chromoly steel (2X stronger than billet steel)
* F1 Racing Lightweight Chromoly flywheels incorporate special design features to enhance the airflow for improved clutch cooling
* F1 Racing Lightweight Chromoly flywheels work with every clutch including Exedy, ACT, Fidanza, Clutchmasters, and other OEM clutch kits
* CAD designed, CNC machined and computer balanced
Release Bearing (Made in Japan), Pilot Bearing and Alignment Tool
F1 Racing Stage 2 Heavy-Duty Pressure Plate (Made in Japan)
F1 Racing Stage 2 Carbon Kevlar Disc (212mm, 24 spline, Made in Japan)
It may not be as cheap as the used clutch and flywheel above, but it does come with everything needed to do the replacement (bearings & install tool) and it is sealed new.
