***BBS RS***
Hey guys, I purchased a set of BBS RS 064's. They're 15x7 Wheels, originally 5x112 lug pattern but they have been filled and re drilled to 4x100. The offset is 37 and center bore is 57mm.
Does anyone know what size waffle plates, hex's, and logos would fit these wheels? I noticed there are several different sizes, I don't wanna buy the wrong set. Anyone?
I am confused. I assume these are not going on an S2000 but a civic or something. I would just measure the inner and outer diameter of the hub hole to be sure you are buying the right center caps.
It's for my em1 not my S. The bbs cap part # 09.23.221 is pretty much the logo cap that fits on multiple BBS hex's. The hex has another part number and so does the plate.
I noticed several caps, hex's, and plates listed on eBay and elsewhere with different part numbers. Some have measurements and some don't.
Pretty certain you're going to have to source them used as they are usually very hard to find. You could also try contacting BBS directly, I'm sure there's a source it just may not be public knowledge.
I would contact one of the wheel refinishing places like VR wheels or wheel flip there is a ton of different sites. They can probably help you find the parts or at least help tell you what you need.
Elliott-V
Mar 6, 2017 08:54 AM
