16" front 17" back
Old May 22, 2010 | 07:16 AM
GuardianDevil's Avatar
Default 16" front 17" back
I've been thinking of getting TE37s for my '02 Spa but want to keep the OEM width. is this possible with 16 front and 17 back? is this going to help with anything or make anything worse? thanks
Old May 22, 2010 | 09:52 AM
TougeS2k's Avatar
Im wondering the same thing. There is a set of 94' NSX wheels/tires on craigs 16-17'' staggered width too.
Old May 22, 2010 | 10:13 AM
chris2002's Avatar
If stagger and offset are correct, same tire type, should not be a problem. That is how Lotus does it.
Old May 22, 2010 | 10:49 AM
1nate7's Avatar
No advantage. Cars that come with factory staggered diameter (Corvette etc.) also have staggered tire diameter so the sidewall is the same front to rear. It would look strange on a S2000 because you want to keep the tire diameter the same front to rear, you would have more wheel/less tire in the rear.
Old May 22, 2010 | 11:20 AM
Jim@tirerack's Avatar
Former Sponsor
1nate7 is correct. It would work on the car but I do not ssee a benefit to doing it. The other cars where they are staggered they are designed for that. The NSX for instance had a front tire that was 23.1" tall and a rear tire that was 24.9" tall.
If you do this on the S2K just make sure the diameter of the frotn and rear tires are the same.
If I can help let me know.
Old May 22, 2010 | 03:09 PM
I'll probably go with 17" all round. do you know which wheel is lighter? TE37 RE30 or CE28?
Old May 22, 2010 | 08:55 PM
Mar48's Avatar
Do a search on google, I think they are all within a pound or two, so pick the design you like best
Old May 24, 2010 | 01:06 PM
looks like I'll be going for the ce28s then! now all that's left to do is find the money :/ are there any other wheels as light but less expensive??
mlam81
Mar 2, 2011 08:02 AM
kmvguy83
Jul 6, 2006 04:31 AM
Johnny Sack
Sep 20, 2005 08:32 AM
Porsche951
Mar 26, 2003 03:40 PM
JT-KGY
Feb 20, 2002 11:08 AM
