17" or 18" which one?
Old Jul 20, 2009 | 11:17 PM
Vik2000's Avatar
u won't regret it.
Old Jul 21, 2009 | 02:13 AM
GeniFx's Avatar
[QUOTE=s2sik,Jul 20 2009, 11:55 AM] 17s
Old Jul 21, 2009 | 04:12 AM
ZDan's Avatar
The weight difference isn't tremendous either way, but if you peruse 17" and 18" wheel weights in the same model and width, the 18" is always heavier. Then look at same-model/same-width/same-height tire weights, usually the 17" tire is a little heavier, but not always.
The 18" combo will almost always be heavier overall.
Ferinstance:
OZ Allegerita 17x8.5 = 15.6 lb., 18x8.5 = 17.4 lb., 1.8 lb. heavier
Bridgestone RE11 255/40-17 = 26 lb., 255/35-18 = 27 lb., 1 lb. heavier
As for tire weight being "farest"(?) from center, the tread of a 255/40-17 vs. a 255/35-18 is the same distance from center. Any additional tire mass is in the sidewall right at the rim. I would bet that the polar moments of 18" vs. 17" wheel+tire are going to be very close.
In the end, the weight difference and polar moment difference isn't going to be enough to make for a measurable performance difference anyway.
So the question is: Why spend WAY more on 18" wheels/tires for zero performance benefit?
Old Jul 21, 2009 | 06:41 AM
aCab's Avatar
how many people track on 18's vs. 17's?
That should be your answer right there performance/cost wise.
Old Jul 21, 2009 | 10:33 AM
MMM.PWR's Avatar
You made the right choice. 17s or 16s is the only way to go!! 18S look like 19s on the S. (depending on the wheel, but most do)
Old Jul 21, 2009 | 08:17 PM
flipdsm's Avatar
https://www.s2ki.com/forums/index.ph...&f=12&t=717107
Old Jul 22, 2009 | 09:18 AM
GeniFx's Avatar
Ferinstance:
Dident go with 18 cus of performens did go with Ce28 for that reason tho but i like the look of 18 more then 17's thats the reason. To be tru with you i was going to go with 17's but disided to go with 18's the last min. And yes im happy i did. but im thinking of geting a set of 17 for the track now tho. Atleast if the 18" r comps is way to expencive
vietdragontekx
Feb 10, 2015 08:09 PM
stu_c
Aug 26, 2010 04:19 AM
papa#12
Feb 16, 2010 08:59 PM
upsdoc
Aug 26, 2008 01:34 PM
Kertef
Jul 23, 2006 07:30 PM
