17" CE28n's with Azenis 615's
Old Aug 13, 2007 | 05:37 PM
myflys2k's Avatar
Default 17" CE28n's with Azenis 615's
I've been searching for quite a while trying to find out if a set of Azenis 615 in a 225 45 17 and a 255 40 17 would rub on a set of Ce28ns 17x7.5 50 offset and 17x9 63 offset. Car being lowered 1 inch.
Every post i see is never one sided.
I know that these tires in these sizes work fine on a stock set of AP2 rims (at least thats whats most people say).
Help me out please.
Some of you that have used this setup and i alway see the Ce28ns for sale with the azenis on them
Old Aug 13, 2007 | 06:23 PM
globallyoff's Avatar
I'm lowered an inch in front and 1/2 inch in back and have Volk 17" RE30s with same offset. I have Bstone 225/255 with no issues. You should be fine.
Old Aug 13, 2007 | 07:05 PM
myflys2k's Avatar
I'm looking at getting the 615's and im not 100% sure but i think they are a little fatter of a tire.
Someone correct me if im wrong.
Old Aug 13, 2007 | 07:22 PM
SOHCmyDOHC's Avatar
I have 215/255 RT 615's. No rubbing. I had -1 degrees camber front and -2 degrees camber rear FYI. You shouldn't rub but if you do just dial in a little more neg camber.
Old Aug 13, 2007 | 08:11 PM
AP2's Avatar
AP2
You should be fine. The 63 offset is good enough to run the 255s out back and not rub.
Old Aug 14, 2007 | 03:26 AM
myflys2k's Avatar
Ya from what i have read, the front is the problem area for rubbing.
Which explains why a 215 would work. I'm just trying to get the widest tire on these rims...
Old Aug 14, 2007 | 08:18 AM
toddyosh's Avatar
i had CE28s w/ the same offset and 225/255 RT-615s and I had no rubbing...
Old Aug 14, 2007 | 12:31 PM
myflys2k's Avatar
Toddyosh..
How much are you lowered and do you know your camber settings?
Thanks for the info SOHCmyDOHC.. I guess i could alway go with the 215 up front.
Old Aug 14, 2007 | 12:37 PM
toddyosh's Avatar
i had espelir springs but i dont know the camber settings.
im doing 225/255 RT-615 or FK-452 on my new RE30s.
nigoape1
Sep 20, 2010 05:00 PM
NGR
May 31, 2010 10:19 AM
millertown15
Jul 12, 2009 01:09 PM
x s2k x
Jan 14, 2006 08:39 AM
bdoob
May 1, 2005 09:27 PM
