17" Tire Sizing
Old Jan 6, 2002 | 11:20 PM
Shamu's Avatar
Default 17" Tire Sizing
Can anyone help me with wheel diameter and tire sizing for 17" rims? I'm getting some mixed msgs...on TireRack, they suggest 205/50/17 and 225/45/17, while some people I know are running 225/50/17 and 245/45/17...I'm looking for the closest fit to the stock diameter, but I know it won't be exact, so I'd rather it smaller than bigger of the stock diameter.
Thanks in advance for any info!
Old Jan 7, 2002 | 07:13 AM
RT's Avatar
RT
Rich for stock diameters and stock width ratio between frt/rear you should use 205/50-17's and 245/40-17's. Both rolling radii are within 1% of stock, the rears being slightly smaller than stock (incase you were wanting to split some gearing hairs).
Old Jan 8, 2002 | 11:52 AM
ukliam's Avatar
What about for 18"s?
Old Jan 8, 2002 | 11:59 AM
S2R's Avatar
S2R
tire size faq
Old Jan 8, 2002 | 12:02 PM
ukliam's Avatar
Thanks
Old Jan 8, 2002 | 12:21 PM
RT's Avatar
RT
I don't know what the FAQ lists, but the correct sizes in 18" are:
225/40-18 frt
285/30-18 rear
but you're not going to find any reasonably priced wheels that can handle those (the correct) sizes. Go with 17's unless you can afford to go nutty.
Old Jan 8, 2002 | 12:25 PM
ukliam's Avatar
so you should not go with:
225/40-18 Fronts
255/35-18 Rears
then?
Is that right, what would that setup effect, would the handling and traction be bad?
There are several people on here running it, perhaps some comments from you about the differences over stock.
Old Jan 8, 2002 | 12:56 PM
RT's Avatar
RT
[QUOTE]Originally posted by ukliam
[B]so you should not go with:
225/40-18 Fronts
Old Jan 8, 2002 | 02:13 PM
Shamu's Avatar
Originally posted by RT
Liam, this old thread may be an interesting read for you on the subject
https://www.s2ki.com/forums/showthread.php?...?threadid=34606
It boils down to keeping the rears about 25% wider than the fronts.
RT -- are you coming from a pure performance point of view when you say the rears should be 25% bigger than the fronts? I'm running with 255/35/18 rears with no issues in terms of rubbing etc....I was also told that this sizing keeps closest to the stock diameter sizing.
Old Jan 8, 2002 | 04:21 PM
RT's Avatar
RT
[QUOTE]Originally posted by Shamu
[B]
