17" Wheels for the S2000
Who actually makes 17" wheels in the proper offset for the S2000. I know Tire Rack carries only two models and I know there are the Mugens. What other wheels are the right offset, and where can I find them (and/or pictures of them)?
Check it out...
https://www.s2ki.com/forums/showthread.php?...?threadid=31162
Also...Volk TE37's.
17x7.5 +48mm
17x8.5 +50mm
Offset isn't bad...but you can't slam the car.
Also...Volk TE37's.
17x7.5 +48mm
17x8.5 +50mm
Offset is the distance from the centerline of the wheel to the plane of the wheel's mounting surface. The wheels for the S2000 have very high offset which makes it difficult to find aftermarket replacements. If you get wheels with less offset, they get pushed outboard. Some like the look of a wheel that sits flush with the bodywork, or even sticks out a bit. However, you can run into interference issues with the wheel well lip, especially if the car is lowered.
