17x9 +35 stock fenders?
Hey guys,
Wanna see some pics of 17x9 +35 all around on stock rolled and/or pulled fenders. I'm also planning to run either 245 or 255 All around. Is that possible? Thanks |
I had 17x9 +45 w/255 all around... don't think it's possible to have stock fender work. I had to roll the rear and relocate the tab for the rear. I also had to shave parts of the rear bumper. The front was also slightly pulled.
Perhaps if you had a ridiculous amount of negative camber, but other than that I don't think you can fit 17x9 +35 w/o fender adjustments. Or of course if you are 4x4 status. |
It's possible. Check out this thread. It has lots of pictures for reference. https://www.s2ki.com/s2000/topic/846...rey-pearl-ap1/
Ride height and alignment are a big factor here. How low are you? How low do you plan to go? Are you willing to run an aggressive alignment?
Originally Posted by ryuken
(Post 21233190)
It's possible. Check out this thread. It has lots of pictures for reference. https://www.s2ki.com/...grey-pearl-ap1/
"hired someone to do the bodywork on her (sand and prep, fix dents, fill some holes, flare front and rear fenders)" bolded emphasis mine. just FYI. i have 17x9 +45's and lowered to 1 finger gap on all 4 corners. you need fender work period or just enjoy the 4x4 look. |
3 Attachment(s)
I run 17x9x4 with a +42 offset in front and +35 in the rear with 255 tires on all 4 corners. -4 camber rear and -1.8 front fenders rolled, bumper bolt moved and bumper trimmed. No pull and no flare I have very minor rubbing in the front. none at all in the rear.
Attachment 107367 Attachment 107368 Attachment 107369 |
Originally Posted by 05APdeuce
(Post 21235562)
not that stiff at all. I run megan ez streets which are 10k all the way around
17x9 +35 245/45 all around
rolled and pulled just a bit. no rubbing at all but im not slammed. 1.5 finger gap all around https://farm7.staticflickr.com/6128/...52d4c7fd_b.jpg |
you guys he said rolled or pulled is fine just that he wants to keep stock fenders... it will definitely work with a pull, just search for images in the gallery.
