17x9 tirees
Old Nov 5, 2011 | 07:17 PM
JspecVtec's Avatar
Default 17x9 tirees
What is the widest tire i can fit on a 17x9? i want to fit 265s in the rear would that work? i have +45 rpf1s with all fenders rolled. currently running 245s all around but want more grip in the rears.
thanks
Old Nov 6, 2011 | 04:57 AM
ZDan's Avatar
http://www.tirerack.com/tires/tires....=yes&tab=Specs
Old Nov 7, 2011 | 01:14 PM
FuknS2K's Avatar
weather it will fit has a variety of factors that we cant determine. plus you can always pull/flare/add camber to your setup to make them fit. if you want it done then you can do it, it will just take more work on your part.
Old Nov 7, 2011 | 06:21 PM
ummpwr's Avatar
I have 275/40/17 Nitto Nt-05s on my TR motorsport 17x9 wheels, no fender rolling in the rear and im at 12.5in fender to center of wheel
Old Jan 16, 2012 | 09:51 AM
axus19's Avatar
do you have pics of it,im trying to do the same and lower it a lil bit
Old Jan 16, 2012 | 11:43 AM
dc2-2-ap1's Avatar
What are the offsets of your wheels? Based on the size of the tire I would think in the +60-70 range.
Getting that much tire on a +45 isn't going to work ( unless you want to stretch your rear fender and still have poke)
Old Sep 12, 2012 | 03:46 PM
axus19's Avatar
TR motorsports are +60ish
Old Sep 13, 2012 | 09:57 AM
MMisencik157's Avatar
+62
Old Sep 13, 2012 | 02:57 PM
s2000Junky's Avatar
Id stick with 255 and run a good compound. Compound makes a bigger difference then width anyway. The problem with 265/275 is it not only adds unsprung weight, it makes the gearing taller which sucks. Adding sidewall height removes some precision in handling as well.
Also just a side note, the few 265 choices that are on the market have actually looked narrower then the typical 255's for what ever reason. So that obviously defeats the original purpose.
ragtophardtop
Mar 21, 2019 12:05 PM
Mr S2000
Aug 16, 2016 06:46 PM
mmmmit
Aug 1, 2014 10:44 PM
dave_t
Apr 23, 2011 11:16 AM
khiz
Aug 31, 2008 11:08 AM
