18x10 +30?
Old Jun 30, 2014 | 03:23 PM
mongomery1234's Avatar
Default 18x10 +30?
I'm 99% sure they wont fit but I just want a more experienced opinion. Found a killer deal on a set of work meister s13p with tires but they are 18x10 +30. They are wrapped in 275/40/18s. Im currently stock height but plan on shortly going with spoon rear/front wider fenders. Long story short would they fit in the mean time with a roll/pull or would it look incredibly stupid?
Old Jun 30, 2014 | 05:56 PM
ryuken's Avatar
It's going to stick out passed your rear quarter panel about an inch.
Old Jun 30, 2014 | 06:33 PM
With or without the spoon rear add ons?
Old Jun 30, 2014 | 08:37 PM
ryuken's Avatar
I forgot to mention that it'll stick out 40mm in the front with stock fenders. The spoon fronts extend to only 20mm and the rears by 25mm. The rears should work. The front is going to be tricky. You also know you'll have to cut your rear quarter panels to fit the wheels right?
Old Jun 30, 2014 | 08:42 PM
ryuken's Avatar
It can work check out this thread. 18x10 +30 https://www.s2ki.com/s2000/topic/802...cle-life-more/
*edit* after browsing this thread again he's running 18x10 +40 in the front and +30 in the rear with 255/35 all around. He doesn't have spoon rear over fenders but the asm over fenders are also +25 extended.
Old Jun 30, 2014 | 08:53 PM
1nate7's Avatar
Tire diameter is WAY too large, so factor new tires into the total price. They won't fit until you go with wider fenders and even then you will need to stretch the tires a bit and run quite a bit of negative camber.
Old Jun 30, 2014 | 09:29 PM
So all in all paying 700 for the rims/tires really isnt a good deal factoring in the world involved which is what I figured? I'm not trying to go for the Hellaflush look and I don't really want to stretch tires either I knew it was probably a long shot that wouldn't work but I just wanted some other opinions. Thanks!
Old Jun 30, 2014 | 10:17 PM
Manga_Spawn's Avatar
Site Moderator
they won't fit. Take it from someone that crammed 17x10 +35 on the rear these will not fit front or rear even with a 255 let alone the oversized 275. Those would be a better fit on a 370z. You would be looking at some kind of widebody front and rear if you wanted to run them square as well as new tires. Basically you would spend thousands to make them fit so the deal isn't all that great.
mongomery1234
Jan 9, 2015 06:16 AM
4x4 freak
Feb 27, 2014 12:52 PM
Topplayer
Feb 9, 2014 12:08 PM
dtmcnamara
Mar 5, 2011 10:13 PM
Tommi1980
Jan 11, 2007 04:15 PM
