18x9 +29 will it fit?
Old Jul 11, 2013 | 04:19 PM
scuderiax8's Avatar
Default 18x9 +29 will it fit?
I have the cwest carbon fiber fender and currently on wedsports tc105n 17x9 +42 with 255/45/17 tires im not really good in calculating offsets im a noob!
Old Jul 11, 2013 | 04:29 PM
1nate7's Avatar
It will stick out 13mm further, do you have the space? FYI, 255/40 would be a better diameter.
Old Jul 11, 2013 | 04:33 PM
scuderiax8's Avatar
thanks if i get this wheel i can pull the rear some more and maybe run more camber like 2.5 to 3 ?.. this will clear stock calipers with no spacers right?
Old Jul 11, 2013 | 04:35 PM
s2000Junky's Avatar
Are the CF front fenders wider then stock? If not then no wont fit, cant roll or pull CF either so your stuck with what you got to work with. 9" +50 would be about as far as I'd attempt with stock unmodifiable fenders. 9 +29 sticks out 21mm more then +50. Almost an inch.
Old Jul 11, 2013 | 04:39 PM
Manga_Spawn's Avatar
Site Moderator
Cwest are +10 mm over stock. Not sure there is enough room. Also are your rear fenders oem? I feel like they won't fit right.
Something you could do is get washers and put the on the studs measure 13mm then put the wheel on DO NOT DRIVE with the washer on but it will tell you how big of a difference you'd be looking at. And yeah get 255/40/17.
Old Jul 11, 2013 | 04:43 PM
scuderiax8's Avatar
thanks for the response guys yes its 10mm widerthanks manga thats a good one i have stock ap1 rear fenders and rear bumper which are pulled and rolled slightly ..
i actually have the the 18x9+29 already just dont have the time to test fit it
blkswan
May 30, 2018 05:37 PM
pappi16
Dec 20, 2012 07:03 AM
Akuma
Nov 26, 2012 02:05 PM
racecar fun
May 26, 2009 10:03 AM
velocityracer
Jan 29, 2007 09:35 PM
