215's vs. 225's
Old Mar 19, 2008 | 06:16 AM
pup73's Avatar
Default 215's vs. 225's
hi,
i've been debating what tire size to go w/for my fronts. jim from tirerack has been very helpful, and has suggested the 215's. i'm getting RE-01R's. for the rears i know i'll be getting 255s.
can anyone w/these tires comment on the size combos? they'll be mounted on ce-28ns, standard 17x7.5 +50, 17x9 +63.
car is also lowered on espelirs.
i value jim's knowledge, just looking for some members experiences w/ 215s and or 225s, with 255 rears. rubbing will be a concern, since at this point i have no plans to roll the fenders.
thanks for any info
-c
Old Mar 19, 2008 | 06:36 AM
Integra21's Avatar
i have no experience but i BELIEVE with standard offsets you would not rub with 225 in the front.
would like to hear from experience from members as well seeing as i will be in the same boat in the future.
Old Mar 19, 2008 | 07:00 AM
speedworksracing's Avatar
I would say 225's that seems to be the popluar setup.
Old Mar 19, 2008 | 12:34 PM
sillyboybmxer's Avatar
i got 225s on front of mine,...not lowered or anything. but i love the extra contact patch
Old Mar 19, 2008 | 01:56 PM
Swiftoy's Avatar
The 215 RE01R's are I believe 1.3 inches wider in tread width than the OEM RE050 if that is what you are comparing to.
Swiftoy
Old Mar 19, 2008 | 02:03 PM
AP_ONE's Avatar
215/245 on mine, zero rub and Im super slammed!
I also run high offsets.
7.5 front and 9 rear.
Old Mar 19, 2008 | 04:41 PM
pup73's Avatar
Swiftoy
yep, i believe you are correct; so even w/RE-01Rs in 215, i'll still have more contact patch and maintain almost stock stagger (since my rears will now be 255).
i guess what i'm wondering is who has 225's up front, is lowered, and running high offsets (+50), and aren't rubbing?
thanks for any info
-c
Old Mar 19, 2008 | 06:12 PM
22calbr's Avatar
i rubbed with
Old Mar 19, 2008 | 09:46 PM
FF2Skip's Avatar
thanks for any info
-c
I didn't drive much with them on the street, but I do not recall rubbing with the 225's. then again, my alignment doesn't switch between street/track.
I don't consider +50 high offsets either, considering stock is +55, right?
Old Mar 20, 2008 | 12:47 AM
bloose117's Avatar
i have the same offset wheels as you lowered on h&r springs with 225 up front in an advan neova and it rubbed in hard cornering until my fenders were rolled.
