225 on 17x9 +40
I currently have a set of square 17x9 +40 wrapped with 255's that I'm trying to sell, but not a lot of interested buyers, so I might just work with what I got. I know this is not the ideal specs for our cars. I'm lowered 1.25 with swift springs. If I swap out the front tires to 225, would I be able to make it work with just rolled fenders (no pull) and around -2.5 camber?
I think it would work. I ran 9" +45 front with a 225/45, no issues.
Have you looked into something like the Origin Fab offset bushings? That is supposed to result in 7mm inset which should allow you to run at least a 245/40 front. Another bonus is it would help get rid of that "front sticks out more than the rear" appearance typical of a non-staggered wheel setup. Haven't tried them myself, but will be installing them soon on 9.5" +50 square setup.
The lower ball joints push the bottom of the wheel out to gain camber, while offset upper A-arm bushing or an adjustable upper balljoint (like SPC) pulls the top of the wheel in to gain camber. This will increase your clearance up front compared to a lower joint.
When using SPC offset ball joints, dies it affect ride height? I read on Robinettes install write up that it has somewhat an RCA correction. If it does, this wouldn't be good for me because I don't have adjustable suspension to compensate the correction. I'm currently running the Hardrace lower joints without that RCA spacers installed.
Corey Maurer
May 14, 2010 09:48 PM
