245/45 Vs. 245/50 ?
Old Jul 17, 2004 | 08:25 AM
E White's Avatar
Default 245/45 Vs. 245/50 ?
The recommended size for Dunlop SP5000 rears for the S2000 is 245/45/16.
I came across some used 245/50/16s for cheap. Whats the difference and would that cause problems on this car?
Old Jul 17, 2004 | 10:39 AM
TriaXenginE's Avatar
i wouldn't get them because they change the rolling diameter of the tire/wheel and that would be unsafe.
Old Jul 17, 2004 | 11:21 AM
E White's Avatar
I wasn't sure ...
The second number is supposed to be the sidewall height measured as a percentage of the section width (first number).
Therefore: 245/45 = 45% of 245mm = 110.25mm
and: 245/50 = 50% of 245mm = 122.5mm
The difference is only 12.25mm or a little over a centimeter.
However, since this is the sidewall height, does this have to be doubled to figure difference in rolling diameter?
If thats the case, then it becomes 24.5mm and thats about an inch ...
So, the question remains ... does that make a big difference?
Old Jul 17, 2004 | 02:04 PM
dispader's Avatar
yes. it's best to get all tires with the same diameter or as close as you can get. .1 to .3 inches difference should be good.
Old Jul 18, 2004 | 01:45 PM
C6400hp's Avatar
[QUOTE]However, since this is the sidewall height, does this have to be doubled to figure difference in rolling diameter?
I believe you would need to use a factor of 3.14 to ge the rolling diameter
Old Jul 18, 2004 | 02:15 PM
E White's Avatar
How so ...
Old Jul 19, 2004 | 09:12 AM
E White's Avatar
Jim ... any comments?
Mok
Jul 26, 2007 12:09 AM
chris2002
Apr 16, 2007 12:37 AM
OOH-VAE
Aug 29, 2006 10:41 AM
nMeOnE
May 10, 2005 11:12 AM
Scot
May 18, 2001 07:57 AM
