350 Z Rims
Hey I wanted to know if the 06-08 350 Z rims would fit and S2000 they are 18" x 8.0" (front) 18" x 8.5" (rear) with an Offset of 33. Would these size effect handing in a Bad way. and would the fender need to rolled? Plus what your say on nissan rim on a honda?
Thanks
Thanks
You'll need to roll the rears for sure, relocate the bumper tabs, and run at least (if not more than) -2 deg of camber. The fronts will need a flare and negative camber as well.
rubbing will depend on the tire sizes you use.
Originally Posted by Lethander,Nov 10 2008, 04:36 PM
Im sorry i tried the search and no luck. If you can will you post the link to that post. thanks
FYI, these wheels are HEAVY - around 26 lbs. I'd look for the 18" track wheels from 03-05, they are made by Rays and weigh around 18 lbs.
I would not recommend making something fit your car. To drill the wheels out to clear the hub you are taking strength away from the wheels. Factory or OE wheels only have enough load capacity for the car they are on. You could be asking for problems.
