+45 offset all around will fit ? need help!
Old Mar 7, 2005 | 08:59 PM
Birdie's Avatar
Default +45 offset all around will fit ? need help!
Okay I just purchase some 17x8 / 17x9 wheels that are +45 offset all around. I was wondering if you guys can give suggestion on tires size to get, so It wont rubbed. i'll be lowering my car with Buddy Club racing damper.
thank you for your help!
Old Mar 7, 2005 | 09:02 PM
SpeedxRacer's Avatar
Regardless your going to rub in the rear.. as for the front I would suggest 205's or 215's
Old Mar 7, 2005 | 09:06 PM
Birdie's Avatar
so there no way i can prevent rubbing the rear?
Old Mar 7, 2005 | 09:17 PM
The rears are really aggressive in terms of fitment for the S. You CAN make them fit (very aggressive camber + thin tires) but it is not ideal for daily driving.
Old Mar 7, 2005 | 09:24 PM
Birdie's Avatar
umm what tires you think i should go with the back ? If i have to, i might just roll the rear fender.
Old Mar 8, 2005 | 07:31 AM
SIIK2NR's Avatar
Your off by +20mm (should be +63-65mm) in the rear.
You should ask the questions BEFORE buying the wheels.....
Your gonna need to stretch the tire across the rim, minimize the drop if any and add an aggressive camber to the rears.
Old Mar 8, 2005 | 11:54 AM
sleekblackroadster's Avatar
Originally Posted by SIIK2NR,Mar 8 2005, 08:31 AM
Your off by +20mm in the rear.
offsets are KEY with s2000's. +45 for a rear rim is flat out WRONG.
Old Mar 8, 2005 | 11:57 AM
koala's Avatar
I would cancel the wheel order if at all possible. You're going to have nightmares with that.
The fronts are "acceptable" - but still off.
The rears are just too far off.
Old Mar 8, 2005 | 03:20 PM
Trip's Avatar
There are some guys running on spoon wheels with +45, what is the difference ?
I am still waiting for my spoon's to arrive :)
Old Mar 8, 2005 | 06:38 PM
koala's Avatar
Yes, in 16" with narrower tires. But it's not comparable. I had +42 mm for my winter 16" wheels and it was just fine.
