5zigen GN+
recently looking into wheels and a close friend is buying vendor status from 5zigen so he needs a buy in and is offering us cost. Im looking at the 5Zigen GN+ and ive seen it on two S2ks so far but the offset is what im questioning i believe that they are 48+
I've seen a couple of GN+ wheels on s2ks in person and it looks like it clears the rear, but it's pretty close. My BBS are 8.5" wide with +55 offset, so the GN+ wheels would stick out 7mm, which would make it right about flush w/ the rear fender. If you lower it, some negative camber should be enough to keep it from rubbing. How much can you get them for (both 1775/1785 and 1875/1885)?
We are waiting for my friends vendor license to be sent to them, he currently runs HIDplace.com and is expanding to rims 5Zigen, Work , Advan,Volk, TechArt are just a few i remember but like i said he needs a buy in on 5Zigen so i found the GN+ 's when we get the pricelist from them ill pm you.
Would rolling the rear fender help ? ive read where someones got them on with a set of prokits and has no rubbing, so I think thats the root im going 17x7.5 in the front 17x8.5 in the rear Thanks a lot for the comfirmations
Just tell your friend to open an whole sale account with Discont Tire Direct, he will get the same cost as a dealer from them or from 5zigen. Their discount is not much compared to what you will get as a stocking WD.
heres mine with 18x7.5 f 18x8.5 rear with +48 offset all the way round...no rubing whatsoever with tein stech springs...I set up the car with the european alignment of 1 degree in the front and 2 degress in the rear... the tires still wear evenly!!
