5zigen ProRacer GN+
Old Feb 7, 2011 | 11:28 AM
s2k love's Avatar
Default 5zigen ProRacer GN+
I've found a set of 5zigen pro racer gn+.17x7.5 and 17x8.5 with +48 offset all the way around. I have seen these wheels on a few s2ks but not much detail is given for size, offset, rolled fenders, etc. I want to avoid rolling the fenders. I daily drive her. That said...will they fit properly without mods and if so, what tire sizes should I use?
Old Feb 8, 2011 | 04:42 AM
Corey Maurer's Avatar
what does DDing have to do with rolled fenders?
Old Feb 8, 2011 | 11:30 AM
s2k love's Avatar
I meant that I don't want an aggressive set up. It doesn't specifically relate to rolling the fenders.
Old Feb 8, 2011 | 12:55 PM
newyawkballa's Avatar
Banned
A lot. Some of us don't want swiss cheesed fenders
Old Feb 8, 2011 | 01:05 PM
ahrmike's Avatar
https://www.s2ki.com/forums/index.ph...ic=342793&st=0
but, I think I have 5zig rims, but I dont think they're in the offset you mentioned. I can go check on it tonight, if you want.
My rear tires currently rub the bumper tab slightly (-1.5 offset, slight drop), and my rear fenders are rolled by the previous owner, but I dont think it was necessary. With a little more negative camber or stock height, it probably would not rub. My front fenders clear perfectly with my slight drop.
Old Feb 8, 2011 | 05:16 PM
mister x's Avatar
If my math is correct, the fronts should be OK. The rear would only be 9/16" wider than OEM which depending on your drop and tire choice, should also be fine without any fender mods.
I'm running chubby 255/40-17 Star Specs on a rim 1/4" wider than OEM with a 1" drop, I've still got another 1/2" before I'd need a very mild roll.
This offset calculator may help...
http://www.1010tires.com/wheeloffsetcalculator.asp
Old Feb 11, 2011 | 12:24 PM
Duke Togo's Avatar
It's like putting ap2 wheels on your car - with a normal 215 front and 245 rear you'll have no problems with fitment
Old Feb 12, 2011 | 03:52 PM
Frame_Runner__'s Avatar
OP... I have these exact wheels and in the same sizing. I ran them with 215's in the front and 245's in the rear and my fenders were 100% stock. The fronts never had any problems. The rears would briefly rub but only when hitting a mean pothole or something like that, NEVER really bad enough to damage the fender though. Ride height would probably affect whether or not you may rub. Im a good inch/inch n half lowered on coilovers fwiw. After i got my my fenders rolled there was no rubbing whatsoever.
Old Feb 12, 2011 | 07:27 PM
1tsxer's Avatar
You really shouldn't have too much of a problem with those sizes unless you are slammed. If anything you may rub on the rear bumper tab.
Old Feb 14, 2011 | 08:24 PM
kidtofuu's Avatar
Im running the exact same wheels and set up. with a 235/40 in the front and 255/40 in the rear. with lowering springs and didnt roll my fenders. no rubbing. i got a pic
