Acura Type S Wheels on a S2000
Old Oct 27, 2010 | 12:27 PM
Boricua's Avatar
Default Acura Type S Wheels on a S2000
Hey guys!!
I'm new to this wonderful forum and hoping I can get some help.
Well I got a very good deal on a 2008 Acura Type S wheels and they look very clean and nice. My question will be if they will look good on my ap1, have anybody had this wheels on there s2k? If so can someone help me whit some pictures to see how they look? The Type S wheels spec are 5x114.3 17x8 and 45 offset.
I will appreciate any help,
Thanks!
Old Oct 27, 2010 | 12:33 PM
JLUDE's Avatar
You really want to run wider rear wheels than front to allow you to better run wider rear tires. S2000 stock wheels are about 1" wider in the rear for this reason.
Old Oct 27, 2010 | 12:37 PM
Boricua's Avatar
Do you think if I put wider tires on the rear will work the same?
Old Oct 27, 2010 | 12:54 PM
DaPhatty's Avatar
Running a narrower rear rim will affect the driving characteristics slightly. A stock sized tire will bulge slightly on such a rim. A slightly narrower tire reduces the amount of rubber that meets the road. I can't say with 100% certainty that you decrease the amount of traction the rear end will get. But I can say that going with a more narrow rim in the back will look ridiculous.
Old Oct 27, 2010 | 01:50 PM
dammitjim's Avatar
I believe the TL wheels all have a 64.1mm bore and the S2k rear has a 70.1mm bore. Those wheels won't fit the rear of an S2k without modification.
Old Oct 27, 2010 | 02:03 PM
hrpfg2's Avatar
s2k rear hub bore...64.1 and front 70.1
Old Oct 27, 2010 | 02:39 PM
dammitjim's Avatar
Yeah, I had it backwards.
Old Oct 27, 2010 | 05:12 PM
bronxbomber252's Avatar
He has an AP1 so the wheels will be bigger all around. You will need to bore out the fronts to fit. I would recommend a Big front sway bar like the Saner bar to balance out the handling of having the non staggered setup.
Old Oct 27, 2010 | 06:01 PM
afzan's Avatar
edit: n/m
Old Oct 27, 2010 | 06:07 PM
SIchodelic's Avatar
dont do it, it's not staggered
if youre set on that style rim, look at the wed sports
they look nearly identical
