Advans R6
Old Jan 26, 2021 | 11:16 AM
SlowslowslowFast's Avatar
Default Advans R6
Hello,
I am looking to get the Advans R6. These the are specs I am planning to run. I am planning to roll and relocate tabs. I do not want to pull
Fronts
18x9 +43
225/40
Rear
18x9.5 +45
255/35
Please post if you have R6's on your S ( i don't care what spec)
Is it pointless to run the extra .5 in there rear? should I just make it a square set up.
Will I have enough camber this run this spec in the rear?
Also want suggesting's for tire size. I do not have experience with stretch tires.
Thank you
Old Jan 26, 2021 | 12:27 PM
Manga_Spawn's Avatar
Site Moderator
The amount of camber does depend on your ride height. The fronts are pushing it and will likely need a pull even with the stretched tires. I had to pull my fronts for 17x9 +43 with a 245 tire. Things like origin bushings will help in avoiding pulling the fronts. The extra .5 in the rear doesn't really make a difference since you are staggering the tires anyways. Does that spec chance the face of the wheel or anything?
Old Jan 26, 2021 | 01:19 PM
That make sense. I am lowered on H&R. 0.75 inch in the front and 0.6 in the rear. No the face doesn't change with the spec. They both have the same lip size, 54mm. I think I will just run a square set up. If I go any smaller with the wheels the lip size will change. 17x9 +45 is probably the go to set up for just rolling an relocating tabs. I am so surprise that, the 2mm makes a big differences. But there's a chance for no pulling. I'm going to have to go through some more fitment threads. Thanks for the help.
dlq04
Sep 24, 2017 08:12 PM
darkfalcon
Bay Area For Sale
Sep 16, 2017 06:55 PM
zacksdad2
Florida For Sale
Sep 14, 2017 07:31 PM
S2KiChad
Feb 27, 2016 11:57 AM
Legal Bill
Sep 27, 2015 06:59 AM
