advice on tire sizes
Old Mar 5, 2008 | 04:41 PM
rob!'s Avatar
Default advice on tire sizes
I am purchasing a set of 17x8.5 front and 17x9.5 rears for my AP1. Wheels are +46 all the way around. I have a turbo car so i want as wide of a tire in the rear as i can get. My car is stock height. What do you guys suggest I should get. Keep in mind i want to go as wide as i can in the rear for traction.
Rob
Old Mar 5, 2008 | 04:45 PM
ZDan's Avatar
If you want to run wide tires, you're buying the wrong wheels.
From the stickie above:
For the front:
6.5
Old Mar 5, 2008 | 04:53 PM
rob!'s Avatar
so with a 255 tire i will be close... i can run some negative camber and roll the fenders before i do the wheels. that looks like its going to be my only option.
Old Mar 5, 2008 | 05:00 PM
ZDan's Avatar
I'm running 245/45-16 rears on 16x8 +45 wheels, no problemo. You probably would have to roll the fenders to fit taller 255/40-17's on 1.5" wider wheels.
You're going to have problems at the front, though.
Yer rim widths vs. offsets are outta whack. Have you already bought these wheels?
Old Mar 5, 2008 | 05:04 PM
kushs2k's Avatar
this is correct you'll have to relocate the bumper bolt as well
Old Mar 5, 2008 | 05:23 PM
rob!'s Avatar
its the price you have to pay for wanting a nice lip on a s2k. im going to run 225-40 front and 255-40 rear. ill make nessecary adjustments to make them fit. thanks for the help
Old Mar 5, 2008 | 05:27 PM
GrandMasterKhan's Avatar
you can run 255s on the OEM ap2 wheels which are 8.5". I thought you said you wanted the widest tire in the rear not the widest lip.
Your kinda kicking yourself in the face by getting such a wide wheel then only putting 255s on it.
Old Mar 5, 2008 | 05:32 PM
rob!'s Avatar
I should rephrase that. I know i wasn't going to be able to run anything crazy wide due to the wheel widths and offsets. I was looking for the widest i can get given the situation. i was figuring 255's.
Old Mar 5, 2008 | 05:35 PM
ZDan's Avatar
You would have exactly the same "lip" with a 10.5" wide wheel with a 59mm offset, and you could then run 275's.
Old Mar 5, 2008 | 05:42 PM
rob!'s Avatar
okay partner. i got the point. My question is answered no need to keep trying to bash me. i thanked you for your help. I didnt ask what way to run the biggest lip and widest tire. did i? I have a set of wheels, simply wanted to know how wide of a tire i could run end of story. damn.
