After alignment and lowered pressure....still middle wearing?
I went through one set of S03's in the rear of the car with weird tire wear in the middle and not the shoulders, I even lowered tire pressure to try to compensate for this wear. After an alignment I was told the car was off and that it was due to how the car was tracking in the rear that it was the problem. So everything was re-checked and put back in stock configurations for the rear, brand new set of S03's in the back now...but its looking like the middle wear is still happening and not on the shoulders like the middle.... I don't know wtf is going on, I know its not the tire because my fronts don't wear like that. I've heard others with this problem but I thought my problem was solved....any other ideas????
What tire size, rim width, and tire pressures, are you running?
stockers right now with 245 s03's running 25 cold psi...thats not too high, 32 psi is what it calls for stock.
yea, the car doesn't oversteer hardly at all....i might bump the pressure back up to see what the hell is goin on.
yea, ive heard other people having this problem before too.... but I couldn't find the thread to see what else was said at that time, that was like 4 months ago maybe sooner. I bumped my pressure back to 32 psi this morning.
Wish someone who has experienced this before would throw in their two cents worth. I did find the following threads discussing tire wear and pressures:
http://forums.s2ki.com/forums/showthread.p...threadid=128526
http://forums.s2ki.com/forums/showthread.p...wear+AND+center
Seems that everyone thinks it has to be a pressure rather than alignment issue.
Good luck,
RED MX5
FWIW, I've had this problem, but with 255-45-17's on a 9" wide wheel. Most of the wear came over the months that I had the tires at 34 psi with two autocross days (pressure peaked at 40!!). Lowering the pressure to 29-30 psi has evened out the wear, but I could never even out the tread. I also think 245 tires on a 7.5" wheel tends to wear the middles.
