aggressive setup! will it fit?
Old Jan 23, 2008 | 06:52 AM
bullitt5897's Avatar
Default aggressive setup! will it fit?
Ok so I am sitting STOCK... with no drop.
I am looking at the Wedsport SA-70's in 18 in. I know with this offset i will get a nice sunken face on the rims but I am not sure it will fit over the brakes. Now I don't mind some fender rolling and I definitely don't mind camber. so what do ya'll think, Will they fit?
heres what they look like:
Old Jan 23, 2008 | 06:55 AM
negcamber's Avatar
What are the offsets?
18 x 8 +42 and 18 x 10 +32
Old Jan 23, 2008 | 07:48 AM
speedworksracing's Avatar
Those rims are hott, but that offset is a in the rear. I am not sure about the front with bbk's.
P-CarDriver's Avatar
you will need major cutting/rolling/camber...i think most people with that setup actually use an over-fender in the rear..idk for sure about the front.
Old Jan 23, 2008 | 07:49 AM
Sinji is running a similar offset I think his are +35 or 36... so should I run a spacer for the back?
Old Jan 23, 2008 | 08:04 AM
TJF's Avatar
TJF
Certainly not... that would make it worse. Perhaps you need to do some homework.
Old Jan 23, 2008 | 08:15 AM
I know what offsets do. please are there any actual suggestions. on how to get these to work I know people are running similar offsets especially on the rear. I know the fronts will be fine but I am worried about the rear. how far will it stick out? since I am not Lowered I don't have to worry about it hitting the fender in the rear.
Old Jan 23, 2008 | 08:53 AM
Ubetit's Avatar
Actually... you proved you dont.
a 5mm spacer makes a +32 a +27
The fronts are going to need some work too.
Old Jan 23, 2008 | 09:12 AM
I know it makes it +27 its like an extension of the disk plate to the hub pushing the rim outward.
