aggressive setup! will it fit?
Old Jan 23, 2008 | 09:14 AM
bullitt5897's Avatar
I didnt start this thread to debate I just want to know will it fit and what are the mods if any that I will have to do since I am standing stock for right now. Camber I know is a must.
explanation
This is why I said use a spacer. I didnt know if the rim would hit the inner wall thats why I said use a spacer...
Old Jan 23, 2008 | 09:33 AM
KeithM's Avatar
Bottom line is youre going to need a rear overfender to run that offset out back
Old Jan 23, 2008 | 09:40 AM
smracer31's Avatar
They will not fit. The front will need about -2 camber and i would say rolled front fenders nd possibly flared. The rears will not fit at all unless you get over fenders. I suppose with -4 camber in the rear with it rolled and flared they may fit
Old Jan 23, 2008 | 10:31 AM
velocityracer's Avatar
Originally Posted by bullitt5897,Jan 23 2008, 07:55 AM
18 x 8 +42 and 18 x 10 +32
they will NOT fit, bottom line. If you put some over fenders in the rear and cut the sheet metal, and have the fronts rolled and pulled. Than it WILL work
Old Jan 23, 2008 | 11:29 AM
owenxguo's Avatar
You need widebody
Old Jan 23, 2008 | 12:00 PM
TJF's Avatar
TJF
The inner wall isnt an issue for S2000s like it is for some cars. The critical area for our cars is generally the outer lip of the fender.
As a general S2000 rule (not universal, but pretty close) to make wheels fit on these cars, you dont want to push them out, you want to pull them in. That is why your offsets are too crazy.
This is subject to change based on wheel width and tire size, but as another general rule on these cars, you need to be closer to +45 offset or higher if you dont want to do modifications to the body in order to make the wheels fit.
Old Jan 23, 2008 | 12:52 PM
silentdancer's Avatar
i wonder if an 8+30 would work on stock front rolled fenders
Old Jan 23, 2008 | 01:02 PM
Well I did the math and the fronts will fit fine but the rears are still 1 3/4 further out from stock at -3 degrees of camber. meaning they won't fit in the rear but the fronts will fit just fine. hmmmm....
Thanks for all the input guys!!!
Mike
Old Jan 23, 2008 | 01:03 PM
8 +30 is worse than the +42 the 42's will require a lil bit of camber but not too much 30's would be too much. srry.
Old Jan 26, 2008 | 11:06 AM
JCDC2's Avatar
lol the guy you are trying to correct is a lot smarter than you think. he was probably joking.
marquez617
May 25, 2012 07:07 PM
RXDI
Jun 15, 2006 11:05 AM
7SinS
Apr 26, 2006 07:40 PM
yummyph0916
Jul 20, 2004 06:29 PM
Leo Gets
Mar 27, 2003 10:42 AM
