Alignment Specs for Pirelli Zero Nero's
Old Apr 5, 2005 | 10:23 AM
skim's Avatar
Default Alignment Specs for Pirelli Zero Nero's
I'm looking for alignment specs to take to the shop to get my wheels aligned. On my original set of S02's my front tires wore excessively on the insides. After searching the boards I know I'm supposed to flip/rotate the front's after several thousand miles.
I'm looking to get the best wear on my tires on my newly mounted pirelli zero nero's for my MY'02. I did a search and found the following threads, but wanted to find out what is recommended for this specific tire in terms of aligment specs without having the car being prone to stepping out in the rear as I drive it year round in the wet as well.
The owner's manual only states one setting as opposed to a range.
https://www.s2ki.com/forums/index.php?showt...12&hl=alignment
https://www.s2ki.com/forums/index.php?showtopic=105828
https://www.s2ki.com/forums/index.php?showt...00&hl=alignment
I'm still very much a newb, so suggestions and recommendations are appreciate. Thanks for the bandwidth.
Stephen
Old Apr 5, 2005 | 11:47 AM
Jim@tirerack's Avatar
Former Sponsor
I would just say if they wore on the inside shoulder I would recommend just running not as much negative camber. I would also say to run the least amount of toe in on the rear and stay within Honda spec.
Old Apr 5, 2005 | 12:37 PM
03_AP1's Avatar
most modern alignment machines will have s2k specs in the computer, in which case there will most likely be a range.
johngamez
Dec 21, 2012 05:30 PM
iamhomin
13
Nov 2, 2006 11:14 AM
shrike
May 14, 2005 08:58 PM
s2003latrobe
Sep 1, 2004 10:03 AM
1Y2KS2K
Jun 6, 2001 03:58 PM
