Aluminum offsets
Old May 17, 2008 | 10:55 AM
vader1's Avatar
Default Aluminum offsets
I ordered a set of Kosei K1 TS's from tire rack and they came with the center ring installed. With the ring installed the center caps will not fit, but they (the center caps) could be ground down a little and made to fit, but I would have to remove and reinstall the center rings.
Is this do-able? I don't know how to remove them except maybe with a wood block and a mallet, and then hammer them back in. Any suggestions?
Old May 18, 2008 | 09:46 AM
vader1's Avatar
Nobdy has ever removed them?
Old May 19, 2008 | 12:40 PM
Jim@tirerack's Avatar
Former Sponsor
I would think the ring would just come out. If you are talking about taking the cap off you can pop it off after taking the wheel off. If you damage a ring or cap just let me know.
Old May 19, 2008 | 01:06 PM
vader1's Avatar
Thanks Jim, will do. It looks like the ring just hammers into place, but I do not want to pop them out until Tire Rack gets the fronts in stock and ships them. It LOOKS like it will be easy, but every project I undertake seems that way at first...........
Old May 20, 2008 | 09:09 AM
Voodoo_S2K's Avatar
The center caps have to be removeable or else you can't balance the wheel.
Jaydem
Mar 15, 2015 05:52 PM
1FastS2k
Aug 14, 2011 12:30 AM
radtech
Mar 8, 2008 09:34 PM
HKSSupra91
May 31, 2007 04:29 AM
jdmgpw04
Sep 2, 2006 06:42 AM
