Another camber ?
Old Feb 22, 2011 | 07:34 AM
ahutsell27's Avatar
Default Another camber ?
Hey guys most of the advice I came up with about camber was: "the factory adjustment is enough to fix camber issues" but mine is supposedly maxed out, it has been lowered (RSR TI-2000 not sure on drop) and on the rear tires the outside edge looks fine and the inside is down to the cords.
I have found balljoint camber adjustments for an extra 1-1.5 deg of adjustment by Elbach and SPC....any experience with this issue?
Old Feb 22, 2011 | 07:54 AM
Frick Nasty's Avatar
Yeah, Some people don't know what they're talking about or every shop I've been to around here has Incompetent workers........
Old Feb 22, 2011 | 07:56 AM
If you want to get all the way back to stock Camber your gonna need one of those kits
Old Feb 22, 2011 | 07:57 AM
ahutsell27's Avatar
^That what I'm saying, I have lifetime alignment on my car so they have no reason to try and get money out of me
Old Feb 22, 2011 | 08:02 AM
ahutsell27's Avatar
I thinking about getting the Eibach
Old Feb 22, 2011 | 08:39 AM
Dreaming_S2k's Avatar
Factory adjustment should be plenty if you're only dropped 1-1.5"
If you're lower, then...yeah. Even then, you're likely to get some inside wear on the tires, because the car isn't aligned @ 0 even on factory alignment specs.
You could get your rear tires "flipped" every 5k mi or so too to help with the uneven wear.
Old Feb 22, 2011 | 12:52 PM
aCab's Avatar
probably more of a toe issue than a camber one.
Old Feb 22, 2011 | 06:22 PM
ahutsell27's Avatar
I lost the print out but the toe was right on but the camber was off several degrees
Old Feb 23, 2011 | 01:03 AM
ZDan's Avatar
The toe was "right on" what? The spec is a range, and the range is different for AP1 and AP2. IMO you want to be a the minimum end of the range. If you're at the max end of the AP1 range, that is going to give you excessive rear tire wear and goofy handling characteristics.
Something in the 0.2-0.3 degree range total (0.1 - 0.15 degrees per side) is what you want.
Old Feb 23, 2011 | 01:54 PM
Jim@tirerack's Avatar
Former Sponsor
We have a new alignment kit from SPC for 74.00 each corner and that is all you would need. If I can help let me know.
QuangNguyen_89616
Oct 17, 2012 08:23 AM
rustyshackle
Aug 5, 2012 07:09 AM
JAYRS2000
May 28, 2012 12:57 PM
Boost76
Sep 14, 2009 08:31 AM
s2addict
Oct 8, 2005 09:36 PM
