Another "is this going to fit" thread
They currently have a 225/45/17 tire on them. I know the rear will have no problems since its already been modified to fit aggressive setups like this one and I was thinking of swapping out for a 255/40/17. The front I am concerned about.
Any input on tire size and modifications I'll need to do for the front? pics of this setup would be awesome as well if anyone has some!
Thanks
Thanks
Here is a 17x9 +45 with 235 tires and barely rolled fenders. You can see it definitely does poke...I replaced all the fender clips with zip ties. I know it was rubbing over large bumps on the highway but seemed to be ok (stock suspension though). I had 255s in the rear.
Hope that helps a little.
I'm only on TEIN springs, I don't think they give enough camber to reduce the poke on a low 40s offset wheel. Anyone have pics of S2000's on low offset wheels with springs?
Originally Posted by MMisencik157' timestamp='1345333337' post='21947473
It works and doesn't really poke depending on camber and how aggressive you get with your front fenders
