another RE-11A thread...
Old May 5, 2013 | 01:30 PM
  #21
ramblin_wreck08's Avatar
Originally Posted by andrewhake
The RE-11A is incredible. Having just come from a set of same sized RE-11 and no other changes to my car I can say without question the provide noticeably more grip, and retain all the other great qualities of the RE-11. The only thing I can really say is the RE-11A compound makes a bit more noise at the limit, but nothing crazy.
You really have to scrub them in for a bit for them to reach their potential. I have put around 1000 miles on them (75% touge driving) and they are really reaching their potential now. If at the track I would say it would probably take four twenty minute sessions to really scrub them in depending on the track surface. The grip before they are scrubbed in isn't bad at all, but wow when they come alive they really come alive. Bananas.
I was running 35 cold all around to begin (out in the mountains in the middle of the night it is usually pretty cool so getting temperature into the tires takes a bit more, and I am usually doing only 10-15 minute runs) but I will be switching back to my usual 32 cold all around for pressures, aiming for around 38 hot. I find that setting a cold tire pressure makes way more sense. There are so many factors that will contribute to how much the tire heats up and changes pressure, and it is always tough to get a consistent way to measure hot tire pressure without a normal pit stop routine.
Great info. I'm going to get a set soon (hopefully). What size are you running front and rear? What kind of tread life did you see from the Re-11's?
Old May 5, 2013 | 01:38 PM
  #22
andrewhake's Avatar
I am using 225F/255R on OEM AP2 wheels. I got 6714 miles out of my RE-11s but my usage is... unique. I would imagine most people would get 16,000+ if not more.
More thorough review.
Old May 5, 2013 | 04:33 PM
  #23
Thanks so much. It was great reading through your thread. So much information.
Now just to decide on the size (F/R) - 215/245, 215/255, or 225/255. For autocrossing, I'm thinking the extra stability of the 215/255 setup might help with consistency, but I'm worried it would make the car push a bit. Then there's the matter of the grip of the 225's vs the more nimble (in theory) 215's. And balance of the 215/245 or 225/255 setup vs the 215/255 setup. So many decisions.
patinum
Apr 28, 2015 03:46 PM
TheKleinschmidt
Sep 10, 2008 07:35 AM
ace123
Aug 2, 2008 10:15 AM
NDAZONE
Jan 12, 2002 08:22 AM
