Another Will this fit
Old Dec 29, 2011 | 06:53 PM
2leftshoes's Avatar
Default Another Will this fit
17x9 +43 (concaved) non staggered on stock height and on a 1" drop
Old Dec 30, 2011 | 04:35 AM
Jim@tirerack's Avatar
Former Sponsor
You are going to have to modify the fenders and run narrow tires with negative camber to make this fit.
Old Dec 31, 2011 | 01:54 AM
2leftshoes's Avatar
how narrow would i have to go? and estimated amount of camber as well
Old Dec 31, 2011 | 05:21 AM
RedCelica's Avatar
17x9 +60s on 255s work fine non-stag., but just barely (little rubbing in the front at full lock). You will need to roll your fronts and rears to give you at least 9 more mm of clearance in the rear, get a 5-10mm spacer in the front and then flare the fronts to avoid any rubbing. Did you read the fitment guide sticky?
Old Dec 31, 2011 | 01:07 PM
2leftshoes's Avatar
yeah i glanced over it a few times but i was hoping the fronts would work out easier, ps i was referring to caved work cr kais on all four, the idea just popped up in my head randomly and i wanted to see if it was possible or if anyone has done it before
Old Jan 1, 2012 | 06:45 AM
LagunaBlu2k's Avatar
Fellow Mid A'ers car. I personally love how it looks.
Old Jan 2, 2012 | 04:06 PM
Froth.'s Avatar
With some fender work you can fit 245's and 255's out back on that wheel/offset. (Rolled flat, relocated bumper tab)
With more fender work you can fit the same on the front. (Rolled flat, flare, trimmed splash shield)
Depends on how low you are, at stock height I would at very least roll the fenders.
1" lower I would roll/relocate.
A local here has 17x8.5 +38 and 17x9.5 +38 CR-Kai's with 215/245 tires and it's slammed and almost never rubs. Depends on your level of fender work.
Old Jan 6, 2012 | 04:44 AM
Former Sponsor
It also depends on whether you want it to never rub. Everyone that posted say they almost never rub. The 245/40R17 would be the tire size I would also recommend.
If I can help let me know.
Old Jan 6, 2012 | 12:25 PM
2leftshoes's Avatar
hey lagunablue2k can you hit me up with the username of the member? i would love to pm him for more info
and thanks for the replies guys lots of good info!
Old Feb 25, 2012 | 11:54 AM
2leftshoes's Avatar
how would the front be with asm front fenders? and rear overfenders?
pjf1985
Dec 15, 2013 10:41 AM
BowlofRice
Oct 19, 2010 12:13 PM
lilmrtinnie
Mar 29, 2007 02:47 PM
s2k_aristo
Dec 30, 2006 10:51 AM
wheresbao
Jun 15, 2006 12:14 PM
