Another Will It Fit ?
Old Mar 31, 2012 | 02:05 AM
panta's Avatar
Default Another Will It Fit ?
Hi everybody !
I'm after a beautiful set of BBS LM in 19"... I know that it's too much but it's not the question here
Spec : 9.5X18 ET25
I know that I'll need fender work But will it fit and what kind of tire size can I use ? I thought 225 front and 255 for the rear or 265 if it can fit ....
I also have an AP Racing BBK ... Don't know if it will clear.
Thanks for your help !
Old Mar 31, 2012 | 03:53 AM
AndrewLin's Avatar
that's an ultra low offset for that width. you're gonna have to roll and pull ur fenders while running a good deal of negative camber and stretch ur tires. 225s might clear if you're not too low
Old Mar 31, 2012 | 10:01 AM
Manga_Spawn's Avatar
Site Moderator
Offset is way to low unless you are planning to do a wide body. You will need rear over fenders and different front fenders to even have a hope o fitting those with the tires you listed. Otherwise you will have to run the stupidly small tires Andrew mentioned and that will ruin your grip and handling.
Old Mar 31, 2012 | 04:20 PM
camuman's Avatar
Ignoring the crazy offset. 275 will fit fine on a 9.5. U could even get a 285 on it if u want.
Old Apr 1, 2012 | 12:36 AM
panta's Avatar
Thanks for your comments !
I'll try and if it doesn't fit, I'll sell it and go for another set.
thanks guys !
Old Apr 1, 2012 | 11:57 AM
S2K-F8's Avatar
Plan on selling them then
I have LM's (18's), the rears are 9.5 +55 with a 265/35 tire. I tried to reverse mount them (effectively making the offset ~+42) and I was rubbing bad, couldn't even drive the car.
Bumper tabs are relocated and fenders are rolled and pinched. Lowered on PSS9's...dialed in as much neg camber as possible with the stock hardware, no go.
Scott-
Old Apr 1, 2012 | 11:59 AM
RedCelica's Avatar
Crazy low offset...you'll need overfenders. Happy selling.
Old Apr 1, 2012 | 04:17 PM
Y0N1P8T5R1F5A4T's Avatar
Herrafrush is not cool anymore. Don't ruin what the car is made to do.
chiney_dolly
Apr 20, 2009 12:21 PM
Mike_Larry
Aug 10, 2008 12:00 AM
HondaS
Jun 29, 2007 10:04 PM
lilmrtinnie
Mar 29, 2007 02:47 PM
-KEY!S2K-
Dec 11, 2006 07:46 PM
