anyone running 225 front and 245 rear on AP1?
Old Dec 24, 2010 | 08:32 PM
vietdragontekx's Avatar
Default anyone running 225 front and 245 rear on AP1?
anyone running 215 in the front and 245 rear with no rubbing issue? and lowered? any modification needed?
wheel spec are :
17 inch +32, 8.0 wide FRONT
17 inch +30, 9.5 Wide REAR
if not, recommended spec? for front and rear?
should i run 215 in front?
Old Dec 24, 2010 | 08:43 PM
Jphoa's Avatar
You are nuts!! Im running 18x9 +50 and 255/35's in the rear and Im rubbing with stock fenders. I cant imagine 9.5" and +30 offset. Apparently 245's on a 9" +50 wheel will clear any rubbing issues. You will definitely have a difficult time without a full roll and a slight pull with that.
Old Dec 24, 2010 | 09:25 PM
yeh just getting idea since i have a set from my evo.
Old Dec 25, 2010 | 11:16 AM
deepbluejh's Avatar
The tires are fine, the wheels are not. Prepare to mutilate your car to make them work right.
Old Dec 25, 2010 | 12:27 PM
CKit's Avatar
Sell Evo wheels, buy S2000 wheels.
Old Dec 25, 2010 | 06:30 PM
justind's Avatar
people on here talk out their asses with no actual experience running sizes like these. those are NOT hard to fit, even on a slammed s2k. if youre really low id prob run a 215/45 on the front. The rear will fit with a 245/40 with a roll/relocate, and the fronts will fit with a roll, and some decent camber on front and rear as well. Im currently rolling on a 9 +35 in the front with a 215/45 tucking tire with no rubbing issues, the rears im thinking about stepping up to a 10".
Old Dec 25, 2010 | 09:47 PM
what about this setup? will it work on ap1?
Gram Lights 57S 5x114.3
Front rims 17x8. +22. Tire size. 225/45/17
Back rims 17x9.5. +22. Tire size 245/45/17
Old Dec 28, 2010 | 10:13 AM
clarkster009's Avatar
Offsets in the 20s are tough on our cars...I would stick more to a high 30 or somewhere in the 40s. I am running a 255 on a 9 +45 rear wheel and it is pretty flush with the rear. A 9.5 +22 would stick out a lot.
Old Dec 28, 2010 | 12:00 PM
Jim@tirerack's Avatar
Former Sponsor
You would have to pull the fenders out to make those fit.
butdamnbrian
Mar 4, 2014 08:44 PM
DesiS2k
May 30, 2010 09:40 AM
SpaYellowS2k
Feb 24, 2009 08:35 AM
707S2K
Jun 18, 2008 10:02 AM
nj2tn
May 27, 2007 11:14 PM
