AP1 Rear tires
Old Mar 11, 2006 | 06:21 PM
Avionics86's Avatar
Default AP1 Rear tires
I bought the car with these tires on it
Fronts Bridgestone potenza pole posisition S03 205/55ZR-16 91W
Rears Bridgestone potenza pole posisition S03 225/50ZR-16 92W
The front tires look pretty good but the rears are shot. From what I have been reading I totally have the wrong tires. The car is stock and not lowered and will not see snow. Just looking into replacing the rears. Now here is the question do I need get the same replacement or do I go with the 245/45YR-16 in the pole posisition S03 from Bridgestone?
Need some advice please
Thanks
Old Mar 12, 2006 | 06:47 AM
jaws's Avatar
Old Mar 12, 2006 | 10:14 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
If you get anything,other than SO2,W89,get 245/45/16
Old Mar 12, 2006 | 11:02 AM
Avionics86's Avatar
Thanks for the information- Just one last question I will go with the 245/45/16 for the rears. Would it make any difference if the fronts are Z rated and the rears are YR rated? All four tires will be Bridgestone Pole Position 03. Tire Rack has them for $202 each and does not carry a 245/45/16 in a Z rating. Just want to get it right the first time around.
Thanks
Old Mar 13, 2006 | 03:47 AM
DiamondDave2005's Avatar
That shouldn't matter at all.
revere
Mar 17, 2008 06:13 AM
Moddiction
Mar 13, 2008 06:15 PM
Hamiy
Feb 20, 2006 09:42 PM
mhaines
Aug 19, 2004 12:48 AM
