AP1 Rears on front
Old Dec 29, 2012 | 02:04 PM
Boss-S2K's Avatar
Default AP1 Rears on front
I recently broke two of my NT03's so I want to put my AP1 rears onto the front. I understand that without boring them out I would be able to use them by using at least a 5mm spacer. However, what if I wanted to use a 20MM spacer to have them sit flush to the fenders?
To my understanding, I would need a spacer for a 70.1 center bore, I would definitely want them hubcentric. However seeing as the AP1 rear wheels have a center bore of 64.1, would this even be possible?
I'd just want to verify this before spending anything. If my hunch is correct, the only way to do this is to have my AP1 rear wheels bore'd out to 70.1 and then run the spacers?
Thanks for the help.
Old Dec 29, 2012 | 03:30 PM
Wolf95's Avatar
Interesting concept. I didn't even realize the bore was different until you said something.
Old Dec 29, 2012 | 03:59 PM
Mr. Lin's Avatar
15mm spacer with studs and put a 70.3mm bored 5mm spacer on that for your 20mm.
Old Dec 29, 2012 | 04:18 PM
Boss-S2K's Avatar
So basically stacking spacers? Is that even safe? I mean I understand it, but, sounds sketchy, no? None the less, something I haven't thought of. Pretty interesting concept.
Old Dec 29, 2012 | 04:22 PM
JUSTINTHECOASTIE's Avatar
I wouldnt stack them, use the 15mm one only
Old Dec 29, 2012 | 04:27 PM
Boss-S2K's Avatar
But it won't clear the center bore of the 15mm hubcentric spacer.
Old Dec 29, 2012 | 04:47 PM
buy front 15mm hubcentric spacers
Christiancruz2672
Nov 19, 2015 09:40 AM
mrkjsn
Aug 20, 2008 04:53 AM
RogerHinga
Jul 4, 2007 11:47 AM
