ap1 tires
Old Aug 10, 2011 | 02:33 PM
ryan2103a's Avatar
Default ap1 tires
i got a set of ap1 rims for $100 and was planning on using them as my temporary rims til i can afford to get better rims but i cant decided on the tire size. my ap2 isn't lowered and i was thinking 225-50-16 front and 245-50-16 rear. will this be okay or is there a better setup.
Old Aug 10, 2011 | 07:23 PM
ZDan's Avatar
205/55-16 front, 225/50-16 rear.
Old Aug 10, 2011 | 09:27 PM
ryan2103a's Avatar
thanks ill check this out
Old Aug 11, 2011 | 07:39 AM
Jim@tirerack's Avatar
Former Sponsor
The factory sizes would be the best in the 16". If I can help with the tires let me know.
Old Aug 11, 2011 | 04:16 PM
ryan2103a's Avatar
thanks for the tip, if i have anymore questions ill let you know.
Old Aug 11, 2011 | 11:48 PM
MrChoi's Avatar
factory ap1 size is used only if you purchase the oem s02. if you are using a different brand tires the correct tire size to use is 245-45-16 for the rear. Front are fine with 205-55-16. I believe there is a sticky about correct tire sizes for ap1.
Old Aug 12, 2011 | 01:55 AM
ZDan's Avatar
Stickie was well-intended, but imo tremendously overstated the importance of "tread width", and is now counterproductive (to the extent that it should be deleted/removed), so please ignore. For one thing, 245/45-16s don't really handle that much differently from 225/50-16s, particularly on the street. For another, there are next to no 245/45-16 street tires available, and if you insist on that size you are guaranteed to NOT have anything like the best tires for your usage.
Old Aug 12, 2011 | 04:08 AM
bronxbomber252's Avatar
Yea the only tires available in the 245-45-16 size are inferior to the top tires by more than enough that they will handle worse.
Old Aug 12, 2011 | 07:01 PM
ryan2103a's Avatar
thanks for the tips guys, so if i get this correctly 205-55-16 is good for the front and the rears?
sorry im a newbie when it comes to tires. i also checked the forums but couldn't find anything.
Old Aug 13, 2011 | 02:05 AM
ZDan's Avatar
Wha? I don't see anything in this thread that suggests that...
