Ap2 v3 wheels
I currently have 4 front wheels, can these be mounted on the s2k? I know they aren’t meant for it as the wheels aren’t staggered but if someone wanted to use them, what are the consequences and also what size tires would be needed if you were to go this route.
They'll fit. center bore is larger on the front wheels, as opposed to the rear. This keeps the wider rear wheel from being installed on the front of your car. I've run 4x OEM front wheel plenty of times on my S. you wont have any issues of them contacting any part of the body.
Consequence? probably less available grip...
Not ideal, but you could run them without major issues, IMO. Lots of tire size options, you might consider running 205/50-17 fronts with 225/45-17 rears to get some tire stagger, although rears would be slightly pinched... Or you could run 215/45-17 and 225/45-17. Or 215s all around. Or 225s all around.
Lookswise, the rear outer wheel lip of the 17x7 +55 will be 9mm more sunken-in than that of the original 17x8.5 +65 rear wheel. Could run spacers, but that would be $$$ and effort that could be expended toward getting some actual 8.5" rear AP2 V3s...
Thanks for the info guys. I know the 4 rears are a no no because of the hub but wasn’t too sure about these. Thanks again for the feedback. As for finding rears, ap2 v3’s aren’t exactly too common. Rarely see them on the marketplace
Yeah it is fine. Another reason the fronts can be put on the rear is in case you have to use the spare you are never supposed to put the spare on the rear. It'll kill your diff. So you are supposed to put a front wheel on the rear and the spare in the front. As others mentioned not ideal due to being really narrow just drive carefully and try to get rears sooner rather than later.
musicforthedeaf
Apr 8, 2015 02:28 PM
