AXIS REVERB PICS
What is the weight of these wheels?
What is the mass moment of inertia (MMI) of the wheels?
MMI is a better way of determining the effect of different wheel setups on QT/HP delivery to the ground.
Did you consider going with the 18x7.5 front and 18X8.5 rear with appropriate tires to get them to fit properly.
I have a concern with the hollow spokes is there provisions to allow water that might collect in these holes to drain out?
Example of problem would be after a wash some remaining dirty soap/water would be in the tube and would drain out when the car is moved (dirtying what you just washed)
or worse the water does not fully drain/water gets in the hollow area during driving causing an imbalance in the rim during driving.
Did you consider going with a 255/35-18 on the rears to see if the rubber still rubs the fender.
Based on what I have seen here I am thinking of going with
18X7.5 +?? 255/40-18 front
18X8.5 +45 255/35-18 Rear
Unless some one has has issues witht this setup or will the 255/35-18 on the 18X9.5 will actually work on a MY04 with 1.5 inch drop.
After some extended email traffic I was able to get the following info
Reverb
18X7.5 +42 19 lbs
18X8.5 +45 20lbs
18x9.5 +55 23lbs
Hiro
18x8.5 +45 23lbs
19x8.5 +45 26lbs
19x9.5 +55 27lbs
You don't need to take them, back just run 255/40 front and 255/35 rear and all problems should be solved.
My plan after today is going to be the Hiros 18x8.5 225/40-18 and 19x9.5 255/35-19 with an inline yellow box to compensate for the additional 1.2inches added over stock diameter on the rear. Staggered both in with and diameter.
Reverb
18X7.5 +42 19 lbs
18X8.5 +45 20lbs
18x9.5 +55 23lbs
Hiro
18x8.5 +45 23lbs
19x8.5 +45 26lbs
19x9.5 +55 27lbs
I wish I had seen this post earlier. Never really look in this section when I am on. Anyway, I have black Axis reverbs on my 2001 Spa. The place that sold them to me told me they were sending me 18x8 in the front with a 45mm offset and a 225/40/18 tire. For the rear they told me they were gonna send 18x9.5 with a 55mm offset and a 255/35/18. When I put them on and drove it down the road sure enough it scrapped. I bought a motorcycle like a day later and haven't driven the car scince. I think if I had a 215 in front and a 245 in back it would do the trick. I am getting rid of my bike this year and putting the car back on the road. I might purchase some new wheels. I can't wait to see the inside of the rim to look for the offsets. If anyone might have an interest in buying some black reverbs when I find out the wheel specs please let me know they will be pritty cheap.
Nick
Nick
