BBS STI Rims on the s2000
I know!!!... That's what I was thinking too. I don't understand why the mod of having the rims bored out if is the same lug pattern?? I was thinking of asking the person if I can try the wheels on the s2000 and go from there
OMG guys. Have you ever looked at your hubs before? have you honestly never changed a tire?
oO <-- those o's are different sizes and so are the hub bores on the STI wheels and the S2000 wheels. S2000 wheels match the hubs on the car exactly.
If you run extended wheel studs and a 6 or 7mm universal spacers, you could get away from boring out the STI wheels.
OR you can get some custom spacers made that are hubcentric to the the S2000 and the BBS rims in any size you want
http://www.wheelspecialists.com/services
Trust me guys, I've ran these wheels on my Civic Si. In my opinion, they aren't worth the trouble.
You're confused. The bore is the centre of the wheel where the centre cap goes, not the diameter of the bolt holes.
^No. The STI wheel bore is smaller than the s2k so the only option is to get them bored out or run a spacer large enough to get past the issue with the smaller bore. Hubcentric rings are to fill the space when you are running a wheel with too large of a bore for your hubs.
